That front crossmember turned out pretty good.
Doubler skid is almost complete. The front of the two runners that run parallel to the frame attach to the front side of the trans crossmember.
did you ever consider grinding the dirt and paint off the frame before welding to it?
Scott, FTAC '99
'89 "CJ-7" - Her trail rig
scott.schubring@williams.com
I wire brushed it and hit it with sandpaper. I didn't do any area that was not being welded to because alto/spring creek mud is gross. Besides that what the hottest setting on the welder is made for right?
Apparently radiusing corners is against his religion as well
Worked all weekend long. The doubler skid is done and painted, I made a chevy 52/waggy 54" hybrid rear spring pack, I also
got the rear 60 and new spring perches ready to go. I finally got this hoe on some tires. I need to redo the rear spring hangers to get some more uptravel with the longer waggy springs. Also, it currently sits about 2" taller with the 42''s at wheeling psi than it was on the 35's.
Anyone know if chey hydro clutch systems use a plasctic spacer on the mounting surface for the slave cylinder that is attached to the bellhousing?
Do i spot some gangster lean?
why is the radiator not where it's supposed to be?
remind me to stay away from this "Klogger waiting to happen" in Clayton
Scott, FTAC '99
-Karl
1965 Chevelle
1975 Corvette
