ATD-5495
Fixed Load Testers
• Battery Test: Quickly indicates your battery's state of charge. The battery load test simulates the cranking load and evaluates the battery's ability to crank the vehicle.
• Starter Test: Identifies excessive starter current draw, which makes starting difficult and shortens battery life.
• Fixed load of 125 Amps
• Tests 6 and 12V batteries
• 300 to 1000 CCA
• Shock-resistant movement accurate to ± 2%
• Heavy-duty, color-coded, copper-plated clamps
• Tests for excessive starter draw
• Tests 6 and 12V charging systems
• Solid state computer chip automatically turns off the load after 8-10 seconds and locks the voltage
• Tests: load test, state of charge, charging system test and starter test
