This is the picture you are henceforth required to post whenever Trainbait is mentioned.Originally Posted by jwingfield2k
is that all you guys got? the engine is a good idea when it works that is. if anyone has ever driven a 6l, they know its a fun engine to drive in- its got great pickup, as long as it works as it should. But i would like to know how a rear end accident can cause an oil leak? Has anyone ever known someone to be re ended at 30-40mph and have it crack the engine? I even slid with the train, just kinda gracefully glided if you must
i have just come to the conclusion that wingnut gets the Lifetime achievement of being a dumbass award....
nice bent frame, don't tell me your truck is back to 100%
do you have friends?
So he got rearended by a train...enough said.
Let it go.
30-40 mph by a train is a little different than 30-40 mph by a miata. theres this thing called mass...
KE=1/2mv^2
therefor: if a miata weighs in at 1 ton and a 100 car train weighs in at 10,000 tons, then there is 10,000 times more kinetic energy in a train than a miata at the same speed.
a few simple physics calcs results in a force from the train impact being around 14000 lbs and from a miata a scant 2800 lbs, but the miata calcs were oversimplified so the force would actually be significantly less than that.
i can definately see it causing a cracked engine since all the stuff behind it is shoved up into it.
you know, i even defended you there for a while but this is getting ridiculous and way to hard to not partake in.
well the engine is evidently in there so does this thing run or what?
don't you think it would have cracked at a mount? I'm not saying the truck perfect after the wreck, but I would think it would have drivability issues, not engine problems unless it was apparent like a cracked mount.Originally Posted by agjohn02
I like him, do I count?Originally Posted by Violentv8toy
Originally Posted by Snatch Adams
im three. i like him. he's just too easy to make fun of to resist.
