Alright guys there are a few questions, well really opinions i would ike to get from you all.
Below are two pictures of the bracket i want to build, that pertains to the trac bar,frame,coil tower(upper), and shock mount.
There are a few reasons i want to build this bracket, and they are; ford tracbar mounts(in stock position) are know to break. usually this is because of them getting loose from the extra stress of lifts, big tires, heavier axles. so what i want to do is move/unite the tracbar mount, coil upper, and new shock mount into a single piece ( so that it will spread the excess force of the trac bar, out more than the stock 2 inch piece) that will stretch a large section of the frame prolly 15 inches or so on the outside of the frame, and 10or 12 on the inside. older ford frames like mine are already boxed in the area of the tracbar mount and coil tower on the inside.
this bracket will use 8 holes on the outside of the frame, and 6 on the inside boxed portion, along with two under on the bottom of the frame. i am going to mount the tracbar underneath the coil tower basically so that i can run a centered(stronger lower(axle mounted side) trac bar mount.
on the inside of the frame i am thinking about making a brace that would run from my new frame bracket to the stock crossmember that is forward of the boxed section by about 10 inches, and also slopes down gradually- meaning that i would have to make a mount on the stock cross that is raised slightly to make a level or almost level brace-this brace would be removable by using heims on each end so it would be removable( and i have some extra 5/8 heims laying around. But my question is since this new brace would be at like a 35-45 degree angle depending on fitment- will it remove enough stress to be justified in the fabrication of the bracket and removable link(brace).
Alright you people that are engineers and what not take a look at the drawings and tell my what you think, or what i could do to make it work, i am pretty sure it would be more than strong enough with just the outside to inside bracket( U shaped basically) to surfice. also btw the plate used for the bracket will be 3/8in.
