1. Where can you find the inner C's, and knuckles for a ford D60 for a decent price? Other than happening upon them used? I know Dedenbear and crane sell them, but I'm thinking more like oem parts (cheaper). Also, how much would you say the parts from the knuckle out of a Ford D60 are worth (Caliper bracket, caliper, disc, spindle, hub, lockout).
2. Did D60s and 14bolts come with the u-bolt plates that sit on top of the spring from the factory? Or do they all hang under the axle like stock yotas?
3. If a beefed up tierod (1.5 OD) was used in the stock location, would there be enough room to mount a 2.5in hydraulic ram between it and the axle tube? I know I've seen alot of rigs running a 2in ram in that location, but didn't know what the size limit would be. I'm also guessing there may be a difference between Chevy/dodge and ford on this matter, because I hear the fords tie rod sit in closer.
4. How do you tell what size u-joint your yoke uses?
More questions to come as I think of them. I know some of these are kinda dumb, but I'm still new to this domestic stuff. And no, I haven't sold the buggy or the toy axles.
