Got an 8 groove. Its 1 more than I need, but the spacing is the same. If that doesn't cut it, custom pulley time.
I would like to do a similar thing on a chevy TBI motor, but make the bracket where the smog pump goes. There is a cholo who makes one for where the A/C compressor goes, but f' that, then you don't have A/C
What do you have that has AC and TBI?
the vette? you could always run ****ty tires on it and not worry about flats!
No more downshifting on overpasses?
not any more
It'll do time travel speeds now
I will confirm this. Still no smokey burnout a though.
Its a little better since you rode in it. The o2 heater grounds were not hooked up, thats why it was doing funny things with the mixture. The coil condensor wire was broken and I think causing some noise in the sensors, and there was some alternator/tensioner **** not right that was causing the belt to slip or something and the voltage was floating around 12 to 12.5
I think if I tried a smokey burnout the smoke would be from the transmission
I brought my 5-gas analyzer back with me, maybe Friday night or before I pass out on the M-Streets we can see it it will pass emissions.
cool. bring bail money
Need to do this too.
http://c7743.r43.cf2.rackcdn.com/Dow...le-air-gap.pdf
11 degrees of base timing allows smokey apartment parking lot 1 tire fires. Haven't tried it yet with the center diff lock and arbs on
Since the transmission was slipping so bad in clayton I was worried about making it home its rebuild time.
I'm putting together a better ZF to match the 4.6 using parts out of a bigger electronic zf 4hp24 stuffed in a mechanical zf 4hp22 case
differences:
E and F clutch
same clutch packs
rear housing is different to accommodate governor on the mechanical ZF 4HP22
Freewheel clutch
Output shaft necks down on the 22, must use 22 output shaft to fit rear F clutch housing
C and D clutch
D clutch has 1 more clutch pack, finer teeth on clutches
C clutch is the same
1 way clutch is stronger on the 24
A and B clutch
A clutch is huge, 15mm longer. Major difference between the 22 and 24
B clutch has 1 more clutch pack, housing c clip location is machined different for extra clutch pack thickness
