Anyone have this laying around? I need them for the ambulamps!
If anyone happens to have a secondary set, or doug you find you came across two sets, let me know. Would like to change this out in the Firetruck.
Doug I have a nasty pair from a suburban that would completely need to be reupholstered. I also have an extremely nice pair from a suburban that a racoon went doodoo on but after a steam clean they'd be great. Nice ones are blue cloth
I have decent seats from my blazer, but the brackets are obviously wrong. You have any brackets from a truck with buckets?
I put suburban buckets in Pigpen, its easy. Your amberlamps already has the hardest part figured out with the raised pedestal on the body for the front inside foot on the seat. The front outside foot is the same between truck and burb and the rear two tabs on the burban seat bracket just need to be bent up 90 degrees to sit flat on the floor, then drill holes for bolts. You don't even need to heat them to bend. I'll give you the ****ty burban seat brackets. If the blazer seats mount to them they should work super. I'm probably going to Kingsville the weekend of 9/21 and can get you the brackets after that.
a little birdy told me your expedition rig is now a tailgate rig.... and as i now have another m1008 i have heard good things about a 2003 ish f250 single cab seat swap in my research. just saying. little mod and lots of comfort.....
