Page 32 of 45 FirstFirst ... 22 28 29 30 31 32 33 34 35 36 42 ... LastLast
Results 466 to 480 of 671
Thread: Diesel Truck Shiat - Per Cook's Request...
  1. #466
    Sand Man Shaggy's Avatar
    Dec 2007
    San Antonio or Victoria
    Well the dodge is over 100K, time for some work. What programmer does everyone wack off to? I don't need something with a gazillion hp increase but wouldn't mind a little. DPF delete for sure. Exhaust recommendations?
  2. #467
    Jan 2010
    Travis has a Smarty Jr. seems to work well
  3. #468
    Registered User texasxj's Avatar
    St. Hedwig
    Smarty jr or a H&S. Wouldn't worry about exhaust, just put tube in place of nox/dpf and keep muffler and cat. The muffler is there for looks anyway once you get past the dpf stuff. Keep anything you take off!!!
    Diesel Truck Resource forums has a hole thread about deleting. Its a good read.
    Clayton Rollins '08
    210-863-1435
    2007 Dodge Ram 3500 4x4 5.9
    1983 Waggy
  4. #469
    Jan 2010
    In case anyone with a 7.3 ever gets leaky up pipes, I found a bellowed up pipe kit for 200 on rock auto which is a good $100 less than other places. I read only good reviews. P/N is 679-005
  5. #470
    Chief
    Sep 2008
    Finally getting in on the diesel circle jerk... 45mpg kicks ass.
  6. #471
    Jan 2010
    You gonna put an intake tuner and exhaust on that thing?
  7. #472
    Chief
    Sep 2008
    Not going to fk with it until after 100k. In the mean time it will get some window tint since it's ungodly hot outside.
    Took me 4 hours to completely uninstall the old sound system and put it back to stock. Will probably be a 30+ hour install to put everything in... beginning this week
    Here is my box of crap that was removed.
  8. #473
    Curious what real life MPG is.
    Jeremiah has a 10 and said it used to get 45 but needs some sort of EGR filter and only gets 38 now
    Nice ride
  9. #474
    Jan 2010
    Can you delete the EGR? Everything I've seen says emissions equipment only worsens fuel mileage.
  10. #475
    dont forget you need to do timing belt every 60k or so
  11. #476
    Of course I do this after 5 on a Friday. 45k fuel filter change and the socket slipped off the "nut" and it broke. Hope ford is open tomorrow
    45k and no issues. Fuel/air filters every 22500. Oil every 7500. $25 in DEF every 6k or so
  12. #477
    DFCM cap. Seems like a very common problem. Internet says $20-30 part.
  13. #478
    And I thought the duramax filter was a pain in the ass.
  14. #479
    Actually super easy to change both of them if this one doesn't break
    This one on the frame does hang low. Doubt it would last one of my Colorado trips.
  15. #480
    Jan 2010
    I'm surprised Evan's didn't break when he changed his last. The plastic was making some weird noises.
    Saw this the other day; it's a 6.7 truck with over 500k on it.
    http://www.youtube.com/watch?v=D3MfN...ature=youtu.be
