Vilas made me a new steering stop.
Bottom side machined out so it doesn't hit the seal.
Tie rod tabs, I went ahead and made them out of 3/8" since I had it laying around. (Mock up bolt)
Tucks up nicely behind the tie rod.
No bead stiffeners?
I think money was tight. These were to be used at tcc but we ran out of time to mount the tires.
hope you can get these studs out if you f them up
did you even lay out the welds so the wheels would be close to balanced, I would have welded it solid all of the way around.
Plenty of room on mine to put in a new stud (if you can find one), put the nut on, and pull it in with an impact. Think I have the same centers and doubt you are going with tons of backspacing.
