I'm kind of tired of staring at the pile in the garage so I'm slowly testing the waters. Next on the list is this axle. It was pulled from a 1990 GMC crew cab truck. The driver side leaf perch was cut off in the process of modifying it for my Jeep but it wouldn't be hard to get it back to stock if that's what you're needing it for. The truss over the differential is not welded and can be unbolted and removed. Lower control arm mounts are welded and might be a little more trouble to cut off but I'm sure it can be done.
$900 if you can pick it up in Dallas.
