start with a CJ-7, wrangler, or TJ - something longer with a better(and wider) frame and body rather than cut up and modify a perfectly fine CJ tub and frame...
You can always put the CJ grill and hood on a YJ tub as I did.
cj5 and cj7 frames are the same width...
build thread:
http://www.tamor.org/forums/showthread.php?t=6982
Even if i started with a tj/yj I would end up stretching the wheelbase and cutting up the body so..... and why would i want a wider frame?
i agree that yj frames are better but as we all know cj front clips rule
i'm a fan of cj5's, i love mine, build what you want and tell everyone else to go f them selves. just look at flem and his retarded rovers
rovers are cool! 5's are cool too - not stretched a ton - and if your a midget.
