Page 17 of 132 FirstFirst ... 7 13 14 15 16 17 18 19 20 21 27 67 117 ... LastLast
Results 241 to 255 of 1980
Thread: Sloth
  1. #241
    Flem graduated in May...kinda.
  2. #242
    Jan 2010
    Can't you run all the stock 350 stuff? What do you need flem for?
  3. #243
    with your mom
    after that comment, tommy you will not be getting you key back, i now own another bronco!!!!
  4. #244
    Ok, I am biting my tongue here, what I meant is that a ford efi setup will not be economically feasable because that would require efi heads, new fuel lines etc.
    Yes tbi is fuel injection but I thought it was different being a low pressure system that injects from one place rather than injectors at each cylinder.
    F*ck off cj.
  5. #245
    Aug 2002
    injects. fuel. according to an electronic trigger.
    google TPI, MPFI, CPI...and TBI
  6. #246
    I think Chevy TBI actually runs at a higher pressure than the Ford injection, but I could be wrong.
  7. #247
    D-FENS agjohn02's Avatar
    Apr 2004
    Cowtown
    Quote Originally Posted by uglyota View Post
    DI
  8. #248
    Hot Beef
  9. #249
    Nov 2002
    Tx
    Hot Beef
    You got a table for that?
  10. #250
    Jan 2010
    I didn't say anything about using ford ****. Did ford ever even make a M motor that was EFI?
  11. #251
    with your mom
    you are wrong karl, you suck!!!!!
  12. #252
    True Hollywood Stry
    Sep 2003
    somewhere in texas
    I'm about 99% sure that you cannot swap efi heads and intake onto an m block. The only way you can do efi is to build a custom intake with injectors in it like Jopes and a couple others of Fsb have done or go tbi/projection(crap).
    Ok, I am biting my tongue here, what I meant is that a ford efi setup will not be economically feasable because that would require efi heads, new fuel lines etc. .
  13. #253
    Aug 2002
    you loose!
  14. #254
    Apr 2004
    Cowtown
    you loose!
    you're smarter than that right? is there a joke im missing there?
  15. #255
    If anyone needs me, I will be in the corner crying. Clarke thinks I suck...
