more like this...
Or like this...in waggy form.
'81 CJ7 Laredo, 258/T176/D300
Got some more rock lovin on driver side, elec fan ate up radiator-just when I thought the overheating issue was not an issue anymore, inverted a shackle and bent sping clamp.
Clayton Rollins '08
210-863-1435
2007 Dodge Ram 3500 4x4 5.9
1983 Waggy
yes I know extreme carnage
Clayton Rollins '08
210-863-1435
1983 Waggy
I was more ribbin you about the ability to actually have an electric fan do any damage at all to the radiator, that is one of the reasons people put them on to keep thier mechanicals from doing the damage.
'you could fawk up a wet dream'
'you could tear up a ball bearing with a rubber mallet'
'you could...
ah, you get the picture.
so what brands of radiators have yall had good luck with?
Clayton Rollins '08
210-863-1435
1983 Waggy
I've got their badood one in my scout.
http://www.usradiator.com/default.htm
the cheap generic ones from summit. griffin with no mounts. pretty much any aluminum radiator you have to put your own mounts on. once they weld mounts to it the price doubles.
How have yall built or seen, drive over fenders for trailers? Gonna start a dovetail and want to knock everything out at once.
Clayton Rollins '08
210-863-1435
1983 Waggy
Some 1"x2" square tubing and some diamond plate can make it look pretty good.
