Page 3 of 56 FirstFirst 1 2 3 4 5 6 7 13 53 ... LastLast
Results 31 to 45 of 839
Thread: Roxanne: 1985 Cj-7
  1. #31
    D-FENS agjohn02's Avatar
    Apr 2004
    Cowtown
    Quote Originally Posted by BMFScout
    I've got the ford pump they are talking about, I guess a 345 with a single 3" exhaust makes me not notice it. Different brands may be louder though, who knows.
    did you just worm clamp the hose onto the barb fittings? no leaks?
  2. #32
    isthat rig upside down or am i crazy
  3. #33
    Wylie, Tejas
    yes on both, check out fuel pump thread. No leaks thus far.
  4. #34
    Some minor alteration. . .installed new turn signal lights up front, (so they work now) and installed relays into the stock cj wiring to brighten the headlights, the best $25 dollar mod i've done so far.
  5. #35
    well i went outside on tuesday of last week to find about a 3 foot long stream of diff fluid comming from the drivers rear outer axle seal. So why i am waiting for parts i thought it was a good time to get some work done.
    1-replaced all front and rear spring bushings
    2-installed some jks b2 front spring plate skid plates that i bought a while ago
    3-and i made and installed some skid plates for the rear, i used the stock front plates and stock rear plates, to make skids and gain an inch of clearance
    4-when i took out the axle shaft i found the wheel bearing race had split in two, whcih is probobly what caused my sudden leak.
  6. #36
    some pictures of the rear skid plates i built
  7. #37
    some pictures of the b2 front skids, i still need to cut off the extra bolts
  8. #38
    the broken wheel bearing
  9. #39
    i got the 2x4 rocker sliders all finished and ready to weld up, but when i mocked them in place i just didn't like how they looked and expecially didn't like how low they hung, so here is what i came up with instead, they are 4"x6"x3/16" angle iron with 1.5x1.5 box tubing steps.
  10. #40
    Wylie, Tejas
    I made plates like this when I was still spring under. They work good. I kept them when I went spring over because I'm cheap and I think they help keep the springs from "fanning out." Much easier to get the nuts off, and they accomplish the same thing.
    http://ih.off-road.com/ih/article/ar....jsp?id=264098
    You needed an excuse to buy ratchet wrenches anyway, I don't know how I lived without them.
    I like the plans for the rock sliders, Will that go almost to the door openings? That's the way to do those.
  11. #41
    Apr 2004
    Cowtown
    Quote Originally Posted by 85cj7
    no joke. i bought new headlights thinking that was my problem. it didnt help. when i put them on relays it made a world of difference. now, everything on the scout is on relays. horn, turn signals, lights. its a good way to get around having to replace a 35 year old wiring harness.
  12. #42
    the sliders will go about 1.5-2" from the door opening, but right up to the bottom of the jeep emblem, if i went with 5" or 6" angle iron I would have to cut a notch for the joop. I'm also thinking about tieing it in to 2 body mounts on the underside, but I don't think they are 100% necessary.
  13. #43
    here are the pics of the first rocker guard with step, all that is left is to drill holes for mounting and paint, and build the passanger side one. Turned out pretty nice, I ended up going with 5x3x1/4" angle and 1.5x1.5x3/16 box. Does anyone think these need to be ties into body mounts or with 4 to 5 bolts through the side of the tub be plenty?
  14. #44
    Apr 2004
    Cowtown
    the way i figure it, with the rails on there, its better to tie them in. if your jeep sits down on the rail, it will create a moment that could buckle your rocker. without the rail, theres no moment and the load goes straight into the tub.
  15. #45
    Apr 2004
    Cowtown
    btw, they look nice. good work.
