You are not supposed to bottom the studs out. Only install the studs into the top of the knuckle by hand. Leave a 16th of slack or so from tight. They are supposed to be in tension, but not torqued into the knuckle. The non-threaded portion is so that the high steer arm and stud have a tighter fit than if it were just threaded all the way.
