Page 74 of 79 FirstFirst ... 24 64 70 71 72 73 74 75 76 77 78 ... LastLast
Results 1,096 to 1,110 of 1174
Thread: Pigpen
  1. #1096
    Brazos County
    my motives ran good
    Seth Stewart '04
    2000 Suburban DD
    1998 GMC pickup - sold
    1975 Scout - TBD
    1976 Scout - parts truck
    1972 IH 1310 dually - TBD
    196? Scout 800 - 302 roller
  2. #1097
    Tommy sucks Sharpe's Avatar
    Aug 2004
    Corpus Christi
    Flem, is it hypothetically possible to install a circuit into a drive by wire computer to activate a 12 volt signal at a certain percentage of throttle? In this case, a TH400 kickdown switch.
  3. #1098
    yes, but I'd have to think about this one. I think there are 3 potentiometers in that pedal and one is the inverse of the other. You could be ghetto and tap into 1 and have it control a transistor that controls a relay, or you could source the plugs, build something that doesn't look like a piece of crap and use all 3 in some sort of failsafe way.
    Are there no solutions to this available? What does the kickdown signal control? Any idea on the amps it would draw?
  4. #1099
    Aug 2004
    Corpus Christi
    There are aftermarket mechanical options but they require a mechanical connection to the throttle. On the ones I have seen, it would be prohibitively difficult to attach to the actual pedal and there is no linkage of any kind protruding from the electronic throttle body. The signal makes the transmission downshift when you mash the throttle. No idea on amperage, but probably blue butt-conector range.
  5. #1100
    find a diagram from the pedal connector and I'll see what I can do
    is 8100 a specific pedal, or is the tac module specific?
  6. #1101
    D-FENS agjohn02's Avatar
    Apr 2004
    Cowtown
    find the right pin on the PCM and see what you can do...
  7. #1102
    Aug 2004
    Corpus Christi
    Pedals are universal, TAC's are app specific.
  8. #1103
    Aug 2004
    Corpus Christi
    Foty toos. About 4 years in the making...
    Brand new TSL's on the rear, worn out IROKs on the front. Respect.
  9. #1104
    Jan 2006
    DAAAnngerrr Zone!
    Bout damn time you got them new shoos on! Looks good. Ought to be a real panty dropper at shiloh!
    'Cause if she don't,
  10. #1105
    Jun 2005
    Krazy Krosby
    Looks good, what is your wheel base? It looks long.
    -Karl
    1965 Chevelle
    1975 Corvette
  11. #1106
    Jan 2006
    DAAAnngerrr Zone!
    He's around 120 I think.
  12. #1107
    Aug 2002
    you gonna put some toob on that thing?
  13. #1108
    Aug 2004
    Corpus Christi
    Yes, tubework is coming up after a few other projects get done. My wheel base is, in fact, ~120".
  14. #1109
    Respek TdmayfieldIV's Avatar
    Sep 2009
    Respek!
  15. #1110
    Jan 2006
    DAAAnngerrr Zone!
    Sharpe, are your spindle nuts the 'common' ones for 60's? If so, I was thinking of trying to find some for the next time I have to take mine apart. I will have to see what kind I have on the green 60 in the barn.
