Actually wingnut, the rear hanger I'm running are off a 2wd, and the ones I sold you are off a 4x4. The 2wd are about 3-4" shorter, which work perfectly for me because I'm running the 3" longer shackles. Creighton, this one will be able to turn because I will be running crossover steering with hydro-assist added later. In any case, I'm keeping the doors to pivot off of for now (Frick style) and will have two bars over the door holes when I exo-cage it later on. The frame will be cut right behind the rear hanger, so about 12" off the back.
