Ok lets get past the sticker you bastards. I put a brand new optima red top in today and it fired up immediately. Even while it was still cold it hardly smoked at all, I think all the crud from sitting has worked itself out. I discovered I need a new alternator and maybe power steering pump, and also need to change my tranny fluid again cause it still has motor oil in it. The PDC vavle still needs to be replaced, but I've known about that for awhile. This semester I also intend to make a good fan shroud to mount my windstar fans to, build half doors, and fix my gaping hole in the floor.
