Results 31 to 36 of 36
Thread: 92 Jeep YJ
Threaded View
    Trail Pimp Busa's Avatar
    Sep 2003
    Anderson, Texas
    92 Jeep YJ
    It is time to let the jeep go. I am asking 10gs for it. Any one that knows the jeep knows it is worth every penny. Here are all the specks for it. If you want more pictures or have questions send me a text or give me a call. Ryan 972-281-9106. Also I have moved back to Anderson so the jeep is here so if someone would like to look at it.
    Make/Model: 92 YJ
    Engine: Stock 4.0
    Transmission: Stock AX15
    Transfer case: Atlas 5.0 with 32spl front 32spl rear outputs, 1350 yoke front 1350 flange rear
    Wheels: 17 X 9 (6 on 5.5) Mickey Thompson classic II with OMF bead locks
    Tires: 40" BFG Krawlers
    Suspension/Lift: Rubicon Express 1" leaf spring, Sprung over 1" body lift, Bilstein 12? 7100 and Bilstein 10? 7100 shocks
    Drive train
    Front Axle: Spider 9" housing with Dana 60 outers, Axle shafts are 35 spline inner and outer 4340 Moser shafts
    Rear Axle: Ford 9" with 35 spline Dutchman 4340 shafts and disk brakes
    Misc: Both axles have Strange Nodular Iron third member, Daytona pinion supports, 35spl Detroit?s and 5:13 gears
    Extras
    Additional Mods:
    PSC full hydro steering 2.25 double ended ram
    Warn 8000pd winch
    Onboard air with tank
    Low profile Aluminum gas tank
    Custom Roll cage
    Race trim seats with 4point harnesses
    Custom tube fenders
    1" motor lift and a flat skid plate
    1350 front and 1350 CV rear drive shafts
    Custom Rockslides and corner guards
    Flat belly
    Custom front and rear bumpers
    Wheel base stretched 7.5? 102ish
    Ryan Busa
    CP# 972-281-7106
    rbusatoy@hotmail.com
