Results 1 to 2 of 2
Thread: d35 for a yj
Hybrid View
    lowballing someone
    Feb 2005
    Houstonish
    d35 for a yj
    Ive got a 88 yj here that is in need of a d35. pinion broke. So i'm looking for an axle to bolt in since that will be cheaper than getting gears and setting them up. it needs to have 3.07 gears or if it has better gears i need a front axle to match. has anyone seen anything around houston preferably?
    Thanks
    Andrew 832 489 597four
    lowballing someone
    Feb 2005
    Houstonish
    My d35 has a broken pinion but brakes are good it's non c clip
    I picked up a 91 c clip with no brakes and apparently you can't swap brakes between the two. Does anyone have a non c clip axle housing with 3.07 gears or complete backing plates to drums for a c clip d35? Preferably close to houston. Thanks
