Page 122 of 132 FirstFirst ... 22 72 112 118 119 120 121 122 123 124 125 126 ... LastLast
Results 1,816 to 1,830 of 1980
Thread: Sloth
  1. #1816
    Jun 2005
    Krazy Krosby
    Oh, he's made a non-refundable downpayment....
    -Karl
    1965 Chevelle
    1975 Corvette
  2. #1817
    Respek TdmayfieldIV's Avatar
    Sep 2009
    Quote Originally Posted by DRAGOONRANCH View Post
    Yep, got me unstuck. Thanks again!
    Was the center line the same one I was wedged upon on?
    Yeah, I backed off though
    If I had more gearing I might have made it. I was just heating up the tranny.
    Quote Originally Posted by mudtoy67 View Post
    Add note to dash: "Tires will not fit where body will"
    I figured my massive bumper would protect it.........guess not
    F*ck off cj.
  3. #1818
    Jan 2010
    Needs more stinger
  4. #1819
    Jan 2006
    DAAAnngerrr Zone!
    Quote Originally Posted by TdmayfieldIV View Post
    Yeah, stoopid carbs....
    'Cause if she don't,
  5. #1820
    Sep 2009
    Motorcraft 2100.......Didn't have a carb problem.
    F*ck off cj.
  6. #1821
    Sep 2009
    Happy Birthday to me!
    Got it from Karl. It's an ORD 203/205 doubler with ORD triple sticks. Gonna take my time building some pimp ass crossmembers, should be wheelable before thanksgiving.
    F*ck off cj.
  7. #1822
    Oct 2004
    Headed back to the Big D
    this pimp ass crossmember you talk of should be interesting. How is it different than the one that is currently attached to it?
  8. #1823
    Jun 2005
    Krazy Krosby
    Last night Tommy was saying he was going to bend it out of tube. After you left I remembered why I did not do that. Most tubing benders have like a 6" radius die, so in order to go from level with the ground, to verticle, then back to level it requries 2 radius's or about 12".
    Having made a doubler cross member, you can mind f' it to death, in the end, just get under there and make something. I wish I would have cleaned my welds up a little more, but in the end, it was the Klogger.
    -Karl
    1965 Chevelle
    1975 Corvette
  9. #1824
    Sep 2009
    Should be something like this. Alll three crossmembers in 1.
    F*ck off cj.
  10. #1825
    Jan 2010
    If you're going through that trouble instead of bolting in the crossmember that came from karl, you should make sure it has a flat bottom and make a flat bottom skid plate a part of it or that bolts to it.
  11. #1826
    ill be your pickup man
    San Antonio, Tx
    Mine hung down below the frame. That crossmember wouldnt have worked
    92 YJ
    04 F-150 4x4
    11 F-250 4x4
  12. #1827
    San Antonio, Tx
    I had to go back and look at mine. We just did a tubular crossmember for the trans, the factory 205 mount, and a TMR customs rear yoke support off the skid. I never had any issues with that setup. But only wheeled it for 1.5 years, albeit rather harshly.
    I did not use the holes in the bottom of the ORU adapter.
    92 YJ
    04 F-150 4x4
    11 F-250 4x4
  13. #1828
    Registered User
    Jul 2006
    all I can say is make sure you have some sort of secondary support off of the 205 to make sure that you take some of the torque load, once I did that I stopped snapping trans/tcase cross members, something like the mount going to the rear bearing cover in your picture above
  14. #1829
    Sep 2009
    The plan is just to basically copy Karl's crossmember with two cradle bars. One will be on the adapter between the 203 and 205, the other will be off the rear bearing plate. Instead of doing a separate tammy crossmember I'm gonna make a 180 bend and weld it to the front tube and bolt the tranny mount to it.
    F*ck off cj.
  15. #1830
    Jun 2005
    Krazy Krosby
    Like I said, you can mind f' the cross member to death. At the end of the day the picture below shows what Off Road Design has on their website and apparently it works. I am still amazed that ORD, who probably has sold more doublers than anyone, could only find this picture to post on their site....
    -Karl
    1965 Chevelle
    1975 Corvette
