WTB:
Spring Perches
Shock Hoops
8 lug wheel spacers
ubolts/plates 14bolt or dana70 size
14bolt driveshaft joint and straps
6" Hydro ram
WTB:
Spring Perches
Shock Hoops
8 lug wheel spacers
6" Hydro ram
I have 8 lug spacers 2"
i was hoping to get some 1"-1.5" but how much do you want? i only need 2
I think I have a used toyota hydro-assist ram.
my brother may have a set of spring perches, ubolts and plates
KrazyKarl02 please get me some pics and a price. bcolman same for you, please make sure they are for a 3.5" axle tube cause its for a 14 bolt rear axle.
thanks guys, please get back to me asap cause i need it all as soon as possible.
Do you mean a u-joint and straps? You can get both from napa for cheap.
I need the drive shaft part too, I'm making a custom driveshaft with toyota at the tcase end and then 14bolt at the other end.
$100 for a pair
im not sure the size, stock 14bolt size i assume. im probably just gonna pull one from a junkyard.
Likely 1330, maybe 1350. You can measure the cap diameter and width and compare a chart to find out the u-joint size.
I am fairly certain that they make an adapter flange to run a Toyota driveshaft without making anything custom. I may be thinking of a d-44. It's worth looking into before you piece something together.
What are they made out of
