Whats everyone done over the break?
I replaced all my rear brake hardware (springs, etc), replaced a front u-joint that had lost a cap and am in the process of repacking the wheel bearings, just in case.
I've decided finally that i'm not using the right parts, or putting them together correctly, or something b.c. the inner seal one both sides was completely destroyed. When y'all put your hubs/rotors on, do you use a seal actually on the spindle inside the inner bearing seal that is pressed into the hub?? Anyone know the p/n for the seals on a D44?? i use the national 4290(?) pressed into the inside of the hub, is there supposed to be another one? the one i've been using is whats getting torn up. thx.
