turn signal troubles
The wiring on the cheby was in pretty bad shape so I cut all of the lighting wiring off at the back of the fuse box. I just got through rewiring the truck and still don't have turn, but I do have hazards.
I got the haynes manual out and double checked the routing and color coding of the wiring, but no go still. Any thoughts on this?
BTW, I took the instrument cluster out because I am going to put an aluminum plate there and mount new gauges in the future, would the blinker indicator lights not being there be a problem?
Nevermind, I didn't have two flasher modules. Once I moved the flasher to the other slot (which was not marked) the turn signals worked. Off to the parts store tomorrow to get a couple extra.
Glad we could help :gigem:
I owe it all to you BDR. ;)
