I need to bump my rear axle forward a little (~3/4"). Sky-manufacturing makes some blocks (below) that could work. They cost $22, but they would be super easy to make on my own. Plus, I think theirs might be too thick. My center pins only stick out by about 3/16", so I might could get by with something .25" thick.
I've never had to use anything like this, so I'm assuming that they just weld to the axle? And, how is it going to effect my u-bolts? Cause the "flattest" part of the spring would no longer be centered.
Thoughts?
I think this would be way easier than messing around with re-drilling the front spring hangers.
