Complete Chevy blazer drivetrain
$2500obo
Engine:
350 bored 30 over with flat top pistons
Mild Erson cam
chrome valve covers, you know this adds power
Tuned Port Injection with what is supposed to be the injectors for a 350
7730 Ecm with the advanced prominator if you don't know what this is look it up, you can't get it anymore
rotary dip switch option, (holds 10 bin files, adjustable on the fly)
Affordable fuel injection wiring harness
Transmission/transfer case:
th350 rebuilt a couple years ago
NP205 rebuilt at same time, twinsticked recently, needs shifters welded to brackets
Running Gear:
Dana 44 front, (HD model with the big manual hubs) completely gone through, all bearings and seals replaced
New calipers, pads, and rotors
Corporate 14 in rear all bearings and seals replaced, all new brake hardware, drums turned, (no ebrake cables) Lincoln locked, the strong way
West Texas Offroad custom solid chromoly draglink and tierod
1 Ton TRE's
4" tuff country springs, 87 stock k5 springs with teflon inserts in rear with Energy Suspension Bushings
Misc:
all new stuff for the TPI setup, fuel pump, filter, 3/8" fuel line, O2 sensor
York 210r for OBA, Ford big alternator, 2 flowmaster 40 series
Also for sale:
1977 Jeep Cherokee Chief hunting truck. It has a 360 V8, TH400, Dana 44 axles and 35 inch tires. I have a tach and propane injection system that I will throw in too. $500
Pictures
http://www.flickr.com/photos/79075006@N00/page3/
1984 Honda XR500 needs a rebuild $500
