i say timken because because thats all i know or use, otherwise i have no preference
Definitely sounds like a cooling issue. I used to run a universal TCI cooler in front of my radiator/electric fan but it wasn't enough. The th350 started to slip on steep climbs and I burnt up the clutches in a sand drag. Now I have a big B&M cooler with its own electric fan and have had no issues since.
I would be a little skeptical about the current condition of the bands, clutches, and pump in your c6 after getting it hot and slipping it. Even if you put a good cooling system on it now the damage might have already been done.
1. I would just go with the cheap one, like you said it's not going to see high speed.
2. I've had 38"s and now 40"s with stock 60 shafts no problems. Broke a selector on a mile-marker hub but that's it.
3. I bought some perches from Ballistic or BTF (can't remember) but they were long enough for me to drill them out 2"s forward to push the d70 back a little more.
Would it be possible to install a fuel injection system on my dakota, and if so what would be the cost and degree of diffuculty associated with that venture?
it is an 87 3.9L V6
if its carbureted I would imagine you could do a tbi swap. I plan on eventually doing this to my truck. We will need to convince flem to help tho
FUnny, my ZJ has fuel injection. Seems to work pretty well:flipoff2:
But your into 87 Dakotas?:flipoff2:
Can someone explain everything there is to know about a distributor vacuum advance and what it does
just crimp it shut, thats what the p.o of my truck did......................
holy crap..............! I second this! x1,000,000,000,000,000
I got rid of it on the rover. real engines dont have that crap
