Yeah, I'm going to stick with the 33's untill I get some aftermarket shafts or tons. I might get some 35/36s if i find a good deal.
I have 36's for cheap.
I finally got around to working on the jeep saturday.
I modified my old d300 shifter to work again.
http://i580.photobucket.com/albums/s...20-11_1733.jpg
http://i580.photobucket.com/albums/s...20-11_1729.jpg
http://i580.photobucket.com/albums/s...20-11_1732.jpg
http://i580.photobucket.com/albums/s...20-11_1730.jpg
It is not bling cable shifters but it will get the job done. Untill i twin stick later down the road.
I also started on the shifter for the doubler. My original plan was to just make a shifter and figure out a way to make solid linkage work. Then i did some searchin on pirate and found a affordable cable to make a cable shifter. So now i am ordering a mcmaster sealed cable. It will be much easier to package and much cleaner looking this way.
I am in need of a fuel cell. I had planned to reuse my stock tank for a while but when i drained the old gas it looked pretty bad inside and the sending unit was very corroded. So now im looking for a cheap 10-15 gal fuel cell. Also the fuel pump is leaking like a stuck pig so i will have to replace it.
Wheelin the xterra last week gave me the itch to get this thing wheel able again.
Finished up some little thing like brake lines, new fuel pump, fuel lines then got started on a fuel cell mount.
http://img.tapatalk.com/aefd77d3-d9d0-fc2d.jpg
http://img.tapatalk.com/aefd77d3-d9e3-a15c.jpg
http://img.tapatalk.com/aefd77d3-d9f2-fa57.jpg
I waisted a ton of time getting a broke bolt out off the Dana 300 and got started on a rear support for the 300.
I finally got around to ordering a cable for the 231 shifter.
Left to do:
Np231 shifter
New floor
Exhaust
Skid plate
Rear bump stops
I plan to hit up down south Offroad on the 18th for a shake down run. Anybody interested?
I'll be at DSO on the 18th with the Krew from Krosby Kustomz.
Me and Karl, with possible other friends.
Got some more work done Saturday.
Got the fuel cell in.http://img.tapatalk.com/aefd620f-4dd0-5f73.jpg
http://img.tapatalk.com/aefd620f-4de4-c7dd.jpg
Added a rear support for the Dana 300.
http://img.tapatalk.com/aefd620f-4e0e-43f6.jpg
Started on the np231 cable sifter. I finished the transfer case side.http://img.tapatalk.com/aefd620f-4eb0-78cf.jpg
I also finished the exhaust.
This week I'm going to finish the shifter and the rear bump stops then it should be ready for testing.
So everything ready for Saturday?
I took the manifolds off the jeep and lucked out. The coolant leak was from a rusted out freeze plug in the head. http://img.tapatalk.com/aefd70fd-f2a3-2595.jpg
Yes, very lucky, so you going to tap a new one in and call it good? Let me know when you want to go to DSO!
