im guessing the little filter is for OBA? keepin the exhaust quiet i see? also - are those flex universal hoses pretty dependable?
yes, the little filter is for the on-board air. It's very quiet at idle (hardley tell it's running if the fan's off) and still sounds good when the tires are breaking loose in third. :D I hope the flex hose is dependable - it's made by Gates so that makes me feel better.
Originally Posted by shaggy
Originally Posted by davido
done.
as for me, i still have 7 months and 11 days. :flipoff2:
how does that OBA work for you?
haven't used it yet, but I'll try it soon and make sure it all works.Quote:
Originally Posted by agjohn02
Sheesh. All that work and you can't even manage to put the tires on the right way. :flipoff2:
Excellent work man.
Originally Posted by Cajun
:laughing:
the scoops are facing backwards. that trumps the seam on the outside of the bumper anyday!
the jeep on the cover of the last crawl had them like that too.
I already swapped them - last week...Quote:
how did you connect the airlines to the compressor? pics?
I went to the j-yard and got some stock hoses - cut the truck side ends off while was there to get the hose for free...
Then on the suction side I cut the AL "nipple" down by the compressor and slid a hose over it with a hose clamp. On the Discharge side I left the flex hose long and inserted a barbed fitting with a hose clamp. I'll try to get a pic for you.
did you seriously only use 3 grinding wheels, 2 flap discs and 2 sanding discs?!?!
no, I used like 7 just getting the old crap off the frame... That's why I added $500 to the cost which might not be enough...Quote:
I've used about 2 grinding wheels and one sanding disc total on my jeep, and it shows.
Anyway, I'm gonna be in your neighborhood in a little while.
bought some 6x9's and the "pods" fit perfectly! We were pretty happy about that :gigem:
also, our new Texas Horney Toad plates that read "CRAWL" plates are in the mail from Austin :gigem:
