will finish it up tomorrow with a 2x3 rectagular box steel spanning the frame, resting/welded to the hangars and frame...
Welds look pretty good from what I can see. When did you learn how to weld?
are you going to put anything between the two frame rails. the frame in the front is kinda weak from what i have been told. Thats why i put a crossmember in there and also the bumper acts as a second cross member.
also i plan on redoing mine all over this winter should be fun. i am gonna slam her down about 1 inch should be fun.
I can read, can you mike?Quote:
Wasn't that only for TTB? Since ttb puts force on the opposing frame rail? But if you have a straight axle the frame should be like any other frame?
thewre still isnt any real front crossmember in those year model trucks.
i have broke my frame up front 3 times... i suggest bracing it
I can't weld. I tried and sucked. I found a friend of a friend up here to help me out. We drank some beers and finished waht is in the pics in about 2 hours. Tomorrow we will weld in the crossmember thing. It is just easier to do it this way then cutting out gussets and such and welding them to the hangar/frame. SHould be stronger as well.
There is the engine crossmember, which will be cut with the plasma tomorrow. Not all of it, just the area where the diff would hit.
pass. side welds
done
cut about 5-6inches out of the crossmember. I will clean it up withe the grinder tomorrow.
Nice looking welds. Good job so far.:cheers:
hell i've got that same nasty looking crossmember on my ford. maybe it'll get a solid axle swap :D
robert I think you've done enough damage to one vehicle!!!:flipoff2:
