sure is a lot a tractor hiems in the pix on this thread.
that should to be a sign. my .02 on wrap bars and leafs
It is. It's a sign of people that care more about getting out and wheeling than building a rig for months or years on end. :flipoff2: I've been that route. At the rate I work, it would take me a year and a half to get coils setup. But it would be nice since I would gain a lot of turning radius. What's wrong with tractor heims?Quote:
Originally Posted by tigweld
Owned! :)
Originally Posted by davido
in the age of pirate off-roading. nothing at all, they're fancy. in the mindset of a racecar builder, heavy, loose, and gay, like jerry. :flipoff2:
hey! Jerry isn't heavy anymore! ;)
it's hereditaryQuote:
Originally Posted by agjohn02
and yesh, except thinking about it more, you should theoretically break pins first, maybe saving your mains
Originally Posted by BMFScout
oh, sorry jerry, forgot you lost weight. didnt mean to offend you :flipoff2:
I just think by the time you get the wrap bar made, installed, and realize it creates hella antisquat you could have just made a cheap yj bushing four link and gotten way better results. if you want to keep the leafs do a doable shackle deal with a four link seems that would work with little effort. I used to hate leaves but here lately i've seen a bunch of cool setups on desert trucks and I think it would be cool to do a long travel sua rockcrawler.Quote:
SHHHHH Ryan! Don't give the yj bushing secret away! No Frocks man! No Frocks! :DQuote:
like this? DO IT!!!
yes, four link would be better but i was thinking easy.
Ah Grasshoppa. I think you grosely overestimate my powers.Quote:
You're probably right, but I'm scared enough that I assembled my steering myself. In fact, that's already shown problems before when the shaft came loose from the box in Katemcy. So temoprarily loosing steering was scary enough, loosing an axle would be great. I don't think a 4 link is within my skillset. I need a KISS method.
Something else I forgot to ask. Does anyone have any pics of the way Tom Ellison (sp?) at Sunray has his front end setup? I seem to remember them having a cool vertical steel strap thingy. They had several rigs with it in Las Cruces back in the day (probably 5 years ago), but I've never seen it on anything else.
I was originally gonna post something that you should do something like his...i have seen it in person and it is pretty cool. greg and myself talked to him for a little while about it. this was back when everything was still built there. and the reason he wouldnt do SOA on gregs jeep is cause he couldnt find a way to control front wrap. anyway, he said he put a jack under the front tire and mapped out its path in relation to the frame. below is a quick rendering of his design.
That's it! And it was a giant hinge at the bottom so it could let the axle droop more on one side than the other. I wonder if T-Roy has pics somewhere.
How about rubicon express soa yj springs for the front? If your springs are the same dimensions as toy minitruck fronts it would be an easy swap. Dimensions for the springs are: 45" long, centered center pin, 2.5" wide spring, 3" wide bushing. A little can be ground off the metal sleeve in the bushing to make it a little narrower.
I concede that I never drove my rig without the antiwrap bar, much less wheeled it, so I don't know what the characteristics of my rear leaf sprung suspension would've been. However, I notice very little antisquat, certainly not enough to be considered "hella".Quote:
Also, I'd be willing to bet that it'll articulate better than 90% of the link suspensions I've seen.
The front, on the other hand, is another issue. I'm starting to realize that I'm going to need to switch to links up front to get what I want out of my front end. Links solve all of my front suspension issues, pinion angle, steering clearance, and spring wrap. Anyone have any ideas for coils that are reasonably priced, will support my 460, and are about 18" tall?
In short, I know from personal experience that antiwrap bar equipped suspensions can work very well...in the rear.
