I don't think I'm ever really done before a run, but I think I'm about done with what will get done before this trip. Need to bolt up and plumb the ram. I need to look over everything, fluids etc.
Yeah we at least should be able to use that damn grill whenever we want :flipoff2:Quote:
You can have it, I have a better one now! :flipoff2:Quote:
Do you have one that we can bring?
Yeah, not sure how much (don't need no gas got propane!) is left. I'll weigh it if I rememberQuote:
I prefer charcoal thanks :gigem:Quote:
ill be ready as soon as robbie puts a new belt on my power steering :flipoff2:
I can get a brisket from sams club, cook it partially here overnight and then we can wrap it in some foil and throw it in someone's engine bay for the trip to OK.
We cooked a brisket in my bro's buddies honda on the way from NY to NC a couple years back.
yeah, yeah, I'll get on it tomorrow morning after my last final. I had to finish up the other CJ7 this afternoon so we wouldn't get fined...Quote:
Originally Posted by J Cooper
So completely different year but still a good question. 3 Weeks
On Tate Jeep
I have to:
finish Skid/Crossmember
Retube Driveshafts Need new U-Joints too
Finish Installing new Roll cage
Weld grab handles on new cage
Touch up rattle can paint cage
Install seats and center console
Mount Low range cable shifter
Add hood latch.
Seat Belts
Install new Top
Need to add some speakers
Relocate CB
Jason's Jeep:
Install inner fenders for new front fenders
Relocate everything that came off factory fenders
install a new cone style air filter
Cut hood for fender clearance
Install Rock Sliders
Paint and install Sport cage
Install new top
Figure out Drive line parking brake lever in cab
Busa Jeep:
Change Oil
Tighten up Limit Strap in rear
Car Hauler (if I use it and only take one jeep)
Drive over fenders
Car Hauler #2 (Jason using)
Rewire some lights
add brakes to one axle
Option 1
* Load Cooler
* Hop in neighbors jeep or Kevin's Ride
Option 2
* Pull chevy 350
* Gut wiring
* Pull trans and t-case
* Install new 350
* Install Trans
* Install Atlas
* Fab cross members
* Fab Skid Plate
* Wire Engine
* Remove Dana 44, springs, and hangers
* Remove 14 bolt
* Install Sterling
* Install hangers, springs, and Dana 60
* Adapte full hydro to Dana 60
* Driveshafts
* Install "Footprint" style gas pedal
Hmmm, which one is looking more likely....
remove old sushi from fridge
install new sushi in fridge
Reinstall ripped off fender.
Fiddle with carb if I feel frisky.
Replace front bent leaf springs with new RE-1.5 springs.
Replace header flange gaskets to fix annoying exhaust leak.
Replace valve cover gaskets to fix annoying oil leak.
None is really necessary. We'll see how motivated I feel.
