-Distill 30gal of mash
-pack
-pack
Jeep:
Figure out what is wrong if anything with transmission
exhaust leak
put top on
Durango alternator
install PS pump skid thing
Clean insides of all Shiloh mud
Inspection sticker is out.
Trailer:
Think its good
Jeep
-finish welding stuff
-put front axle back together
-top off fluids
-change oil
-build skid plate for the motor/trans/transfer cases
-doors and a windshield would be nice but I don't know if I will get there.
Trailer
-figure out why the brakes aren't working/ replace coils
Truck
-Change oil
-Rotate tires
- finish wiring buggy from scratch
- test wiring, fix anything that doesn't work
- install steering column
- install dash
- final align axles to chassis, make sure it's all square
- cut down extra length of bolts at link connections
- put in heat shield on backside of interior panels
- install driveshafts
- install panels, seats, center console, seatbelts, etc... Finish assembly
- put in brake fluid, bleed brakes
- put in gear oil
- N2 in shocks
- test drive, pray that everything works
- put water in front tires
- load on trailer
- pray that Dodge and trailer and Lynda's Jeep are good to go...
You know me better than that BDR. Oh, and the Suburban is on the injured list. Needs a trans rebuild, tcase chain, and rear axle rebuild. The Brune fleet is in bad shape right now. You should see the planning board in the shop...there isn't even room for Mario or Chip to make a funny comment!
Mostly tommy, probably a 80/20 split.
^^^^^ Agreed
Fix tranny leak-o ring in fill tube seems to be stopping it up
install yoke and front driveshaft from last weekends break
load and go!
You speak the truth JB...
I wasn't having a very good morning and after a frustrating weekend of not getting much done after dental surgery on Friday, I spent most of the weekend on pain killers and taking naps. So I was a bit down about the whole situation this morning.
Today I got news that the Tahoe's converter will be here Wednesday, I should have Lurch's new radiator tomorrow, along with the new assist ram. So now that I know when parts are going to be here, I can start getting some stuff knocked out.
Now to get all of that done so I can build my WTWE gift!
Had a pretty productive week so far. As of tonight, here's the revised list:
Lurch:
-grease all ujoints
-install new stereo head unit
-install different windshield frame and windshield
Trailer:
- Weld deck plate that has broken loose
- Get tire with nail in it patched
- Repack bearings and inspect suspension
- Replace clearance lights on rear
Tahoe
-front end alignment
-wash
Other:
-WTWE gift
-load up
I have a good tj windshield frame. Glass is bad. 75$
I think I am done. Still have to load the trailer, but I think the Jeep, Trailer and truck are squared away finally.
Sweet. Here's my revised, revised list.
Lurch:
-grease all ujoints, check fluids
Trailer:
Tahoe
-wash
Other:
-WTWE gift
-load up
Nice work!
Thanks man!
drain the $70 of joe gibbs break in oil, put in $60 of joe gibbs regular oil
top off all gear oil
1 quart lucas transmission goo
purchase sushi
That NASCAR oil is some good stuff.
Hell yeah.
I switched because I thought the rings werent seating because of the occasional smoke and was desperate for anything to fix it rather than tear it apart. found out this week it was the injector harness corrosion causing intermittent connections and ltft to go high, but the miles I put on it don't make expensive oil that big of a deal
I have the GN hooked to the truck and the Busa jeep sitting out ready to load. Only if I could convince the ol lady to let me go I could be on the road within an hour of getting off work.
