Originally Posted by
TdmayfieldIV
Actually I did and they blew. I had a dual fan set up and they never kept it cool and they drew a ton of power.........Stock cooling set ups work. Especially for mostly stock trucks, like Travis'
1. If you need more cooling add a pusher to supplement your stock system. Or do some gears......maybe then you won't be working the engine so hard to tow. You have 37's and stock gears.
2. All of the other expensive stuff you put on your truck made sense, and was proven
3. It's a valid question, it's a dd. The amount of negative it will probably do on your daily driving plus the money you're gonna spend on it will not be offset by the 5 times you ever get in water that deep. We aren't talking about air filters, we're talking about the fan. For the record I think switching it with the battery is a solid idea.
Do whatever you want, it's your truck. Just don't throw your old parts away.
(you asked for opinions, it's a forum....that's my opinion)
