How do you keep the sandpaper from sticking when wet sanding? Put it on a block or use soap in the water?
I use the foam sponge things and keep a garden hose running. The foam sponge thing keeps you from over doing it with edges, but I'm also no wet sandologist. Oh and if you are wet sanding your diesel smoke spray paint, don't waste your time.
What Karl said. Don't bother sanding the diesel smoke metallic. If you spray it right, it will be smooth and look good. You should spend more time on the primer under it than you do on the diesel smoke.
**** the person that changed the awesome headlight mounting design on chevy's from 99-06 to the bull**** that it is in 07+
get one of these
http://www.optionracing.com/images/e...-INSTALLED.jpg
Where is the best place to get aftermarket exhaust systems for side by sides? My 2012 Ranger Crew 800 has a cracked manifold and all of the spring and everything are rusted out. Muffler is shot too. Sounds like crap and I don't want to cause any engine damage without proper back pressure. I have googled and have not found a complete system out there.
