He has an auto
He has an auto
anybody know how long the a chevy 203 to ford 205 doubler is w/ 1350 flanges?
Oliver Brothers Transmission was good to me when I had my Honda. Never really heard much else about them.
Can I reuse the bolts from my flex plate when I put the new flywheel on?
I believe I did. Just make sure to red locktight them.
make sure there long enough, most flywheels are considerably thicker at the hub than flexplates
Ford Dana 60 ID help? Inner Passenger axle shaft (the long inner), there appear to be 2 different ones for sale, one is 36.97" and one is 36.68". Any idea how to tell the difference? Do they measure this from the end of the eye for the u-joint to the tip of the splined part? Anyone know?
wouldnt it be from center of u-joint hole to end of shaft?
look up the bom number on the long tube. it will tell you what length you need.
What did Ford do to the D60 front in 08+ to make it turn so much more than anything else? Looks just like a 05-07 axle, but turn about like the forklift.
made it three inches wider and new steering box
How big is big enough for a transmission cooler to keep the fluid cool enough to never have to worry about it? I have a small one on my truck now, as well as the one in the radiator and it wasn't enough. I think I'm going to go with a stand alone cooler and not use the one in the radiator so it's not right next to the hot radiator all the time.
And for an external filter, do I just use a remote mount oil filter?
Also, I'm running new lines, can I use some good hose or would it be better to stick with hard line?
biggest cooler you can afford
use the biggest plate style that you can buy/afford, the plate style work better than the ones with fins
