No, that's why they make screwdrivers
$750 for the whole set up
$300 for the alternator
$250 for two new batteries
$100 for smart isolator
$100 in wireing and misc terminals ect.
Everybody's definition of the right way is diffrent I guess.
And there was nothing wrong with the ignition switch, the ignition key cylinder was busted.
You spent 500 dollars trying to fix the wrong bearing (what's the part number?) And get butthurt when someone calls you out for cutting corners on the ignition switch?
I must have missed the ignition switch thing. Do you use a screwdriver too?
Put the new alternator in and realized the alternator bracket had a big crack in it. Cranked it up and it still has a squeal. After talking to Junior he suggested that if the rubber ring in the harmonic balancer was in bad shape it could be throwing the belt out of alignment and causing the squeal. I picked up a new harmonic balancer; new belt and I'm supposed to pick up a new alternator bracket today.
In the mean time while I was waiting on parts yesterday, I replaced my Trans Temp gauge because back light in it stopped working and wired up a small light above the switch panel so I could see them at night.
http://i129.photobucket.com/albums/p...pscmbhxqb1.jpg
http://i129.photobucket.com/albums/p...pscwmgiilg.jpg
http://i129.photobucket.com/albums/p...psz735qs80.jpg
Also trouble shot a reverse light issue I was having. They were very erratic. First I noticed my dimmer switch had a short in it with a multimeter. So I replaced that. Then I started metering other things out and found I had a weak ground to the whole Dash panel and added a ground to it. The reverse lights are working well now but you have to drop it from park to drive to reverse to get them to come on. So now I'm thinking it is the Neutral Safety Switch. However the back light on my climate control is also not coming on except every blue moon. So when I get the time ill pull that out and see what's going on with that.
Anyway ready for this thing to be running right so I can get this lift on.
Replaced the harmonic balancer and put a new belt on. Squeal Is gone. However it still will squeal when you put your foot into it hard. Dropping off my d30 to get geared and locked today hopefully after I pick up my deer meat from the processor. Im going to drive the truck to the coast one last time this weekend to drop off a item to a customer before the thing is ripped apart again.....
Belt tensioner
Belt tensioner is a manual adjusting bracket.
Shackles came in. Pretty beefy!
http://i129.photobucket.com/albums/p...ps1a91ac4f.jpg
Dropped off the dana 30 Thursday to Bryan Drivetrain to get the 4.10s installed and the spartan locker put in. Hopefully I be picking it up in a couple days.
on another note, took the truck down to matagorda this weekend. Put about 400 miles on it total. Ran great. Still has a little churp coming from one of the pulleys until it warms up. Cant tell where it is coming from. Had to go down there to load up the truck bead full of drift wood for a order I have for my business. Also had to drop a order off to a customer. This is the last trip the truck will take before the long arms and 35's are on. If work and school permits I would like to get the old axle out and mock up the long arms before the end of spring break.
Here is a few pictures I snapped playing around on the jetties. The truck did pretty good for only having 2wd right now.
http://i129.photobucket.com/albums/p...ps018465f6.jpg
http://i129.photobucket.com/albums/p...ps2b2ea192.jpg
Well finally got the axle back with the 4.10's in and the spartan installed. I got ripped off it cost me a arm and a leg and took for ever...... oh well nothing I can do about it. Its done now. Hopefully I can install ball joints this weekend.
To those who have set up gears befor, How does the pattern look?
http://i129.photobucket.com/albums/p...psw8kjzw6n.jpg
